Every 90 days I keep having to disable/remove each certificate from each site added in aapanel and go through the process of installing a new one via DNS verification > Cloudflare (api data etc are always configured) and then have it renewed for another 90 days days the certificate of that site, they still haven't fixed it??
Note: the certificate renewal cron job is active and its log is as follows:
|-The domain name skipped this time: ['caixaalta.com.br', '*.caixaalta.com.br'], because the last renewal failed, you still need to wait 24 hours and try again
|-The domain name skipped this time: ['escuderiacoqueiro.com.br', '*.escuderiacoqueiro.com.br'], because the last renewal failed, you still need to wait 24 hours and try again
|-The domain name skipped this time: ['guapile.com.br', '*.guapile.com.br'], because the last renewal failed, you still need to wait 24 hours and try again
|-The domain name skipped this time: ['costasaneamento.com.br', '*.costasaneamento.com.br'], because the last renewal failed, you still need to wait 24 hours and try again
|-The domain name skipped this time: ['crm.caixaalta.com.br'], because the last renewal failed, you still need to wait 0 hours and try again
|-The domain name skipped this time: ['newqualityflooring.com', '*.newqualityflooring.com'], because the last renewal failed, you still need to wait 24 hours and try again
|-The domain name skipped this time: ['sgabryimoveis.arq.br', '*.sgabryimoveis.arq.br'], because the last renewal failed, you still need to wait 24 hours and try again
|-The domain name skipped this time: ['jonathascastro.com.br', '*.jonathascastro.com.br'], because the last renewal failed, you still need to wait 24 hours and try again
|-A total of 7 certificates need to be renewed
|-Renew the visa certificate and start checking the environment
|-Renewing certificate number of 1,domain: ['projetos.caixaalta.com.br']..
|-Creating order..
|-Getting verification information..
|-Verification type: dns-01
|-Error unable to get DNS zone for domain_name=projetos.caixaalta.com.br: status_code=200 response={'result': [], 'result_info': {'page': 1, 'per_page': 20, 'total_pages': 0, 'count': 0, 'total_count': 0}, 'success': True, 'errors': [], 'messages': []}
|-Renewing certificate number of 2,domain: ['lasquadraonline.com.br', '*.lasquadraonline.com.br']..
|-Creating order..
|-Error unable to get DNS zone for domain_name=lasquadraonline.com.br: status_code=200 response={'result': [], 'result_info': {'page': 1, 'per_page': 20, 'total_pages': 0, 'count': 0, 'total_count': 0}, 'success': True, 'errors': [], 'messages': []}
|-Renewing certificate number of 3,domain: ['caixaalta.com.br', 'audiovisual.caixaalta.com.br', 'agencia.caixaalta.com.br', 'mail.caixaalta.com.br']..
|-Creating order..
|-Verify the dir:/www/wwwroot/caixaalta.com.br//.well-known/acme-challenge
|-Verification type: http-01
|-Verifying domain name..
|-1 Query verification results..
|-Verification failed
|-Verification failed, domain name resolution error or verification URL cannot be accessed!
|-Renewing certificate number of 4,domain: ['webmail.caixaalta.com.br']..
|-Creating order..
|-Error unable to get DNS zone for domain_name=webmail.caixaalta.com.br: status_code=200 response={'result': [], 'result_info': {'page': 1, 'per_page': 20, 'total_pages': 0, 'count': 0, 'total_count': 0}, 'success': True, 'errors': [], 'messages': []}
|-Renewing certificate number of 5,domain: ['costasaneamento.com.br', 'mail.costasaneamento.com.br']..
|-Creating order..
|-Verify the dir:/www/wwwroot/costasaneamento.com.br//.well-known/acme-challenge
|-Renewing certificate number of 6,domain: ['webmail.costasaneamento.com.br']..
|-Creating order..
|-Error unable to get DNS zone for domain_name=webmail.costasaneamento.com.br: status_code=200 response={'result': [], 'result_info': {'page': 1, 'per_page': 20, 'total_pages': 0, 'count': 0, 'total_count': 0}, 'success': True, 'errors': [], 'messages': []}
|-Renewing certificate number of 7,domain: ['andresaoliveira.com.br', '*.andresaoliveira.com.br']..
|-Creating order..
|-Attempt to verify DNS records locally, domain name: _acme-challenge.andresaoliveira.com.br, type: TXT record value: kiSe-s8bN8Afu5YLUJQGxjoKlyqMX5MUAWxpqq5PFas
/www/server/panel/class/acme_v2.py:931: DeprecationWarning: please use dns.resolver.resolve() instead
ns = dns.resolver.query(domain, s_type)
|-Local authentication failed!
|-Attempt to verify DNS records locally, domain name: _acme-challenge.andresaoliveira.com.br, type: TXT record value: cWVXRqhZRGsvPTgHr4DPk04XbW_iIhmTINR9fwhnLKA
|-No valid TXT resolution record was found in the domain name ['_acme-challenge.andresaoliveira.com.br'], please check whether the TXT record is parsed correctly. If it is applied by DNSAPI, please try again in 10 minutes!
★[2022-06-27 00:13:01] Successful
|-The domain name skipped this time: ['caixaalta.com.br', '*.caixaalta.com.br'], because the last renewal failed, you still need to wait 0 hours and try again
|-The domain name skipped this time: ['projetos.caixaalta.com.br'], because the last renewal failed, you still need to wait 24 hours and try again
|-The domain name skipped this time: ['escuderiacoqueiro.com.br', '*.escuderiacoqueiro.com.br'], because the last renewal failed, you still need to wait 0 hours and try again
|-The domain name skipped this time: ['guapile.com.br', '*.guapile.com.br'], because the last renewal failed, you still need to wait 0 hours and try again
|-The domain name skipped this time: ['costasaneamento.com.br', '*.costasaneamento.com.br'], because the last renewal failed, you still need to wait 0 hours and try again
|-The domain name skipped this time: ['lasquadraonline.com.br', '*.lasquadraonline.com.br'], because the last renewal failed, you still need to wait 24 hours and try again
|-The domain name skipped this time: ['caixaalta.com.br', 'audiovisual.caixaalta.com.br', 'agencia.caixaalta.com.br', 'mail.caixaalta.com.br'], because the last renewal failed, you still need to wait 24 hours and try again
|-The domain name skipped this time: ['webmail.caixaalta.com.br'], because the last renewal failed, you still need to wait 24 hours and try again
|-The domain name skipped this time: ['costasaneamento.com.br', 'mail.costasaneamento.com.br'], because the last renewal failed, you still need to wait 24 hours and try again
|-The domain name skipped this time: ['webmail.costasaneamento.com.br'], because the last renewal failed, you still need to wait 24 hours and try again
|-The domain name skipped this time: ['newqualityflooring.com', '*.newqualityflooring.com'], because the last renewal failed, you still need to wait 0 hours and try again
|-The domain name skipped this time: ['sgabryimoveis.arq.br', '*.sgabryimoveis.arq.br'], because the last renewal failed, you still need to wait 0 hours and try again
|-The domain name skipped this time: ['jonathascastro.com.br', '*.jonathascastro.com.br'], because the last renewal failed, you still need to wait 0 hours and try again
|-The domain name skipped this time: ['andresaoliveira.com.br', '*.andresaoliveira.com.br'], because the last renewal failed, you still need to wait 24 hours and try again
|-A total of 1 certificates need to be renewed
|-Renewing certificate number of 1,domain: ['crm.caixaalta.com.br']..
|-Creating order..
|-Attempt to verify DNS records locally, domain name: _acme-challenge.crm.caixaalta.com.br, type: TXT record value: 9amNqb8zSi-j8azQ2CtfXC12Y3Ut0SHg8SDpU-0a1k4
|-No valid TXT resolution record was found in the domain name ['_acme-challenge.crm.caixaalta.com.br'], please check whether the TXT record is parsed correctly. If it is applied by DNSAPI, please try again in 10 minutes!
★[2022-06-28 00:11:25] Successful
