5 months later
4 months later
7 days later
shajal This is a very easy task to fix
  1. First put your recycle bin on.
  2. Then delete your databases which will be stored in the recycle bin
  3. Now you uninstall mysql and install it again
  4. Then restart everything again
4 months later
Do not stop mysql at will, stable server hardware is running, etc.
Daily backup database
    2 months later
    You need to stop mysql and then back it up. Note that it may not work properly even after the backup.
    If mysql is running normally, it is recommended that you back up the database directly in aapanel
    aaP_vikingphp
      aaPanel_Kern Backup directory command:
      \cp -rp /www/server/data \www\backup\data_2022
      You told that i have to copy /www/server/data to /www/backup/data_2022,
      Now i want to use /www/backup/data_2022 but when i replace /www/server/data by /www/backup/data_2022 and change /www/server/data ownership to mysql:mysql and restart mysql, mysql stops working immediately. (error: Failed to start mysql service)
      mysql logs:
      2024-11-07T09:20:50.438804Z 0 [Warning] [MY-000081] [Server] option 'max_allowed_packet': unsigned value 107374182400 adjusted to 1073741824.
      2024-11-07T09:20:50.438931Z 0 [Warning] [MY-010915] [Server] 'NO_ZERO_DATE', 'NO_ZERO_IN_DATE' and 'ERROR_FOR_DIVISION_BY_ZERO' sql modes should be used with strict mode. They will be merged with strict mode in a future release.
      2024-11-07T09:20:50.439096Z 0 [System] [MY-010116] [Server] /www/server/mysql/bin/mysqld (mysqld 8.0.24) starting as process 3955312
      2024-11-07T09:20:50.461738Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
      2024-11-07T09:20:50.468074Z 1 [Warning] [MY-012197] [InnoDB] Unable to open './sys/sys_config.ibd'
      2024-11-07T09:20:50.830635Z 1 [Warning] [MY-012573] [InnoDB] './#innodb_temp/temp_5.ibt' permission error, can't delete!
      2024-11-07T09:20:50.830764Z 1 [Warning] [MY-012573] [InnoDB] './#innodb_temp/temp_10.ibt' permission error, can't delete!
      2024-11-07T09:20:50.830875Z 1 [Warning] [MY-012573] [InnoDB] './#innodb_temp/temp_4.ibt' permission error, can't delete!
      2024-11-07T09:20:50.830987Z 1 [Warning] [MY-012573] [InnoDB] './#innodb_temp/temp_9.ibt' permission error, can't delete!
      2024-11-07T09:20:50.831098Z 1 [Warning] [MY-012573] [InnoDB] './#innodb_temp/temp_2.ibt' permission error, can't delete!
      2024-11-07T09:20:50.831209Z 1 [Warning] [MY-012573] [InnoDB] './#innodb_temp/temp_8.ibt' permission error, can't delete!
      2024-11-07T09:20:50.831325Z 1 [Warning] [MY-012573] [InnoDB] './#innodb_temp/temp_1.ibt' permission error, can't delete!
      2024-11-07T09:20:50.831443Z 1 [Warning] [MY-012573] [InnoDB] './#innodb_temp/temp_6.ibt' permission error, can't delete!
      2024-11-07T09:20:50.831566Z 1 [Warning] [MY-012573] [InnoDB] './#innodb_temp/temp_3.ibt' permission error, can't delete!
      2024-11-07T09:20:50.831686Z 1 [Warning] [MY-012573] [InnoDB] './#innodb_temp/temp_7.ibt' permission error, can't delete!
      2024-11-07T09:20:50.831809Z 1 [ERROR] [MY-012592] [InnoDB] Operating system error number 13 in a file operation.
      2024-11-07T09:20:50.831932Z 1 [ERROR] [MY-012595] [InnoDB] The error means mysqld does not have the access rights to the directory.
      2024-11-07T09:20:50.832047Z 1 [ERROR] [MY-012592] [InnoDB] Operating system error number 13 in a file operation.
      2024-11-07T09:20:50.832161Z 1 [ERROR] [MY-012595] [InnoDB] The error means mysqld does not have the access rights to the directory.
      2024-11-07T09:20:50.832281Z 1 [ERROR] [MY-012126] [InnoDB] Cannot create file './#innodb_temp/temp_1.ibt'
      2024-11-07T09:20:50.832410Z 1 [ERROR] [MY-012930] [InnoDB] Plugin initialization aborted with error Generic error.
      2024-11-07T09:20:50.841845Z 1 [ERROR] [MY-010334] [Server] Failed to initialize DD Storage Engine
      2024-11-07T09:20:50.842414Z 0 [ERROR] [MY-010020] [Server] Data Dictionary initialization failed.
      2024-11-07T09:20:50.843045Z 0 [ERROR] [MY-010119] [Server] Aborting
      2024-11-07T09:20:50.845060Z 0 [System] [MY-010910] [Server] /www/server/mysql/bin/mysqld: Shutdown complete (mysqld 8.0.24)  Source distribution.
        aaPanel_Kern I've changed the #innodb_temp folder chmod to 755 and the problem solved.
        But right now i have this error:
        mysql> check table accounts;
        No connection. Trying to reconnect...
        Connection id:    27
        Current database: uploader
        ERROR 2013 (HY000): Lost connection to MySQL server during query
        ERROR 2003 (HY000): Can't connect to MySQL server on '127.0.0.1:3306' (111)
        ERROR:
        Can't connect to the server
        mysql> check table users;
        Connection id:    8
        | Table          | Op    | Msg_type | Msg_text |
        | uploader.users | check | status   | OK       |
        1 row in set (0.56 sec)
        @aaPanel_Kern
