hello. i have a trouble with csript installation.
i dont understan what to do... can anyone help me?
    GN86
    Hello, can you check whether the php version used by the website has curl enabled?
    yusufthoib
    ping google.com -c 5
    I experienced the same thing
    24 days later
    Export blocked ip works similarly to Export blocked record.
    6 days later
    17 days later
    15 days later
    When I click on the post item, specifically the ‘hello word’ post, the page does not display but instead shows a 404 error. We have tried restarting the server and restarting the panel, but none of these solutions work. Please help me. I have enabled URL Rewrite in the WordPress tab.
    10 days later
    After I updated to version 7.0.4, the information was successful, but then an error occurred as shown in the image above. Can anyone help provide a way to fix the error?
    a month later
    [2024-07-15 06:47:42][DEBUG] - Traceback (most recent call last):
    File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 1821, in full_dispatch_request
    rv = self.preprocess_request()
    File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/app.py", line 2313, in preprocess_request
    rv = self.ensure_sync(before_func)()
    File "/www/server/panel/BTPanel/init.py", line 245, in request_check
    return abort(401)
    File "/www/server/panel/pyenv/lib/python3.12/site-packages/flask/helpers.py", line 310, in abort
    current_app.aborter(code, args, **kwargs)
    File "/www/server/panel/pyenv/lib/python3.12/site-packages/werkzeug/exceptions.py", line 864, in call
    raise self.mapping
    (*args, **kwargs)
    werkzeug.exceptions.Unauthorized: 401 Unauthorized: The server could not verify that you are authorized to access the URL requested. You either supplied the wrong credentials (e.g. a bad password), or your browser doesn't understand how to supply the credentials required.
    не открывается не один готовый сайт я имею ввиду не запускается панель входа в вордпресс вот создал новый при нажатии перейти в вордпрес вылезает такая надпись
      Hello, are you using the correct access method? If a website without SSL is accessed using https, it will jump to a website with SSL set up.
      It is recommended that you set up SSL for all websites or use the correct access method
      aaP_barlep52
      SSL настроен правильно все равно не запускается вордпрес
        hello.. How to add a disk to aaPanel?
        I have tried to extend it on Linux Ubuntu 20.04
        but in aaPanel it's still with a 300GB disk, it hasn't changed to 400GB
        maybe i'm doing it wrong on ubuntu, help me please..
          20 days later
          Good afternoon or good morning, after installing aaPanel I am facing problems installing certain php extensions.
          In this new version of aaPanel, many things are not working well, there are many bugs.
          until now I can't install the php 8.1 fileinfo extension
          any solution?
