hi, still error with the installation docker manager
Hit:1 https://download.docker.com/linux/ubuntu focal InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Hit:3 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
Reading package lists...
Building dependency tree...
Reading state information...
ca-certificates is already the newest version (20210119~20.04.2).
curl is already the newest version (7.68.0-1ubuntu2.11).
apt-transport-https is already the newest version (2.0.8).
The following packages were automatically installed and are no longer required:
docker-ce-rootless-extras pigz slirp4netns
Use 'apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Get:2 https://download.docker.com/linux/ubuntu focal/stable arm64 Packages [15.8 kB]
Hit:3 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Hit:4 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease
Hit:5 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease
Hit:6 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease
Fetched 15.8 kB in 1s (17.0 kB/s)
W: Target Packages (stable/binary-all/Packages) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/docker.list:1
W: Target Translations (stable/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/docker.list:1
W: Target CNF (stable/cnf/Commands-arm64) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/docker.list:1
W: Target CNF (stable/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list:58 and /etc/apt/sources.list.d/docker.list:1
The following additional packages will be installed:
containerd.io docker-ce-cli
Suggested packages:
cgroupfs-mount | cgroup-lite
The following NEW packages will be installed:
containerd.io docker-ce docker-ce-cli
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/70.4 MB of archives.
After this operation, 339 MB of additional disk space will be used.
Selecting previously unselected package containerd.io.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 143666 files and directories currently installed.)
Preparing to unpack .../containerd.io_1.6.4-1_arm64.deb ...
Unpacking containerd.io (1.6.4-1) ...
Selecting previously unselected package docker-ce-cli.
Preparing to unpack .../docker-ce-cli_5%3a20.10.16~3-0~ubuntu-focal_arm64.deb ...
Unpacking docker-ce-cli (5:20.10.16~3-0~ubuntu-focal) ...
Selecting previously unselected package docker-ce.
Preparing to unpack .../docker-ce_5%3a20.10.16~3-0~ubuntu-focal_arm64.deb ...
Unpacking docker-ce (5:20.10.16~3-0~ubuntu-focal) ...
Setting up containerd.io (1.6.4-1) ...
Created symlink /etc/systemd/system/multi-user.target.wants/containerd.service → /lib/systemd/system/containerd.service.
Setting up docker-ce-cli (5:20.10.16~3-0~ubuntu-focal) ...
Setting up docker-ce (5:20.10.16~3-0~ubuntu-focal) ...
Created symlink /etc/systemd/system/multi-user.target.wants/docker.service → /lib/systemd/system/docker.service.
Created symlink /etc/systemd/system/sockets.target.wants/docker.socket → /lib/systemd/system/docker.socket.
Job for docker.service failed because the control process exited with error code.
See "systemctl status docker.service" and "journalctl -xe" for details.
invoke-rc.d: initscript docker, action "start" failed.
● docker.service - Docker Application Container Engine
Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Fri 2022-05-20 15:45:42 +08; 6ms ago
TriggeredBy: ● docker.socket
Docs: https://docs.docker.com
Process: 12501 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=1/FAILURE)
Main PID: 12501 (code=exited, status=1/FAILURE)
dpkg: error processing package docker-ce (--configure):
installed docker-ce package post-installation script subprocess returned error exit status 1
Processing triggers for man-db (2.9.1-1) ...
Processing triggers for systemd (245.4-4ubuntu3.17) ...
Errors were encountered while processing:
docker-ce
E: Sub-process /usr/bin/dpkg returned an error code (1)
Requirement already satisfied: pytz in /www/server/panel/pyenv/lib/python3.7/site-packages (2019.3)
WARNING: You are using pip version 22.0.4; however, version 22.1 is available.
You should consider upgrading via the '/www/server/panel/pyenv/bin/python3.7 -m pip install --upgrade pip' command.
Requirement already satisfied: docker in /www/server/panel/pyenv/lib/python3.7/site-packages (4.2.0)
Requirement already satisfied: six>=1.4.0 in /www/server/panel/pyenv/lib/python3.7/site-packages (from docker) (1.16.0)
Requirement already satisfied: requests!=2.18.0,>=2.14.2 in /www/server/panel/pyenv/lib/python3.7/site-packages (from docker) (2.26.0)
Requirement already satisfied: websocket-client>=0.32.0 in /www/server/panel/pyenv/lib/python3.7/site-packages (from docker) (1.2.3)
Requirement already satisfied: charset-normalizer~=2.0.0 in /www/server/panel/pyenv/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (2.0.12)
Requirement already satisfied: certifi>=2017.4.17 in /www/server/panel/pyenv/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (2019.11.28)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in /www/server/panel/pyenv/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (1.26.7)
Requirement already satisfied: idna<4,>=2.5 in /www/server/panel/pyenv/lib/python3.7/site-packages (from requests!=2.18.0,>=2.14.2->docker) (2.8)
/bin/systemctl
Warning: Stopping docker.service, but it can still be activated by:
docker.socket
Created symlink /etc/systemd/system/getty@tty1.service → /dev/null.
Synchronizing state of docker.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable docker
|-Successify ---Script execution completed---
i see the log have an ERROR with docker.
when i make sudo apt update
i got this error form docker
sudo apt update
Reading package lists... Done
Reading state information... Done
All packages are up to date.
after i cleanup
sudo ./aptsources-cleanup.pyz
No duplicate entries were found.
“/etc/apt/sources.list.d/docker.list” contains no valid and enabled repository lines.
Do you want to remove it? (yes/no/all/none/display)
? all
“/etc/apt/sources.list.d/docker.list” removed.
1 of 1 empty sourcelist files removed.
then... i was trying reinstall docker still same error. at the same log above.
can help for this.
