hardikanand1st
For reference
server
listen 80;
listen 192.168.1.128:443 ssl http2;
server_name 192.168.1.128;
root /www/wwwroot/192.168.1.128;
#error_page 404/404.html;
#HTTP_TO_HTTPS_START
if ($server_port !~ 443){
rewrite ^(/.*)$ https://$host$1 permanent;
#HTTP_TO_HTTPS_END
ssl_certificate /www/server/panel/vhost/cert/192.168.1.128/fullchain.pem;
ssl_certificate_key /www/server/panel/vhost/cert/192.168.1.128/privkey.pem;
ssl_prefer_server_ciphers on;
ssl_session_timeout 10m;
#SSL-END
#error_page 404 /404.html;
#error_page 502 /502.html;
#ERROR-PAGE-END
#Clear cache
location ~ /purge(/.*) {
proxy_cache_purge cache_one $host$1$is_args$args;
#access_log /www/wwwlogs/192.168.1.128_purge_cache.log;
#Referenced reverse proxy rule, if commented, the configured reverse proxy will be invalid
include /www/server/panel/vhost/nginx/proxy/192.168.1.128/*.conf;
include enable-php-00.conf;
#PHP-INFO-END
include /www/server/panel/vhost/rewrite/192.168.1.128.conf;
#REWRITE-END
location ~ ^/(\.user.ini|\.htaccess|\.git|\.env|\.svn|\.project|LICENSE|README.md)
return 404;
location ~ \.well-known{
allow all;
# Prohibit putting sensitive files in certificate verification directory
if ( $uri ~ "^/\.well-known/.*\.(php|jsp|py|js|css|lua|ts|go|zip|tar\.gz|rar|7z|sql|bak)$" ) {
return 403;
access_log /www/wwwlogs/192.168.1.128.log;
error_log /www/wwwlogs/192.168.1.128.error.log;
