Hello,
After a recent install of AApanel, I'm unable to load the phpmyadmin feature.
It just says 503 Service Unavailable, the error in error.log is these:
(2)No such file or directory: AH02454: FCGI: attempt to connect to Unix domain socket /tmp/php-cgi-.sock (*) failed
AH01079: failed to make connection to backend: httpd-UDS
/tmp/php-cgi-.sock is missing the version number for php, as looking in the /tmp contains php-cgi-74.sock but it's configured incorrectly, so it's not using that file.
Can I fix in a config somewhere?
Thanks
    aaPanel_Jose
    Thanks, that worked! I completely forgot that it was installed via the apps section.
    Also, is the aapanel repository on github still maintained? I'm happy to fix some of the spelling/grammar issues if pull requests are still accepted.
    Thanks again
