aaP_danzoff1990 how can i add like this in aapanel?? i copy all the config already and add port also but its not works..
aaPanel_Kern aaP_danzoff1990 Hello, different domain names/ips are ok. The same domain name/ip is not supported
aaP_masterjaringan000 aaPanel_Kern As a result, if the public IP is the same only the port is different, then that means it can't work, right?
aaPanel_Kern Yes, you can no longer add a website, it is recommended that you use a domain name aaP_masterjaringan000
