MASeif
DNS Manager
sort: cannot read: ping.pl: No such file or directory
--2022-04-27 01:19:15-- https://node.aapanel.com/install/0/dns_manager.sh
Length: 6765 (6.6K) [application/octet-stream]
Saving to: ‘dns_manager.sh’
0K ...... 100% 40.2M=0s
2022-04-27 01:19:17 (40.2 MB/s) - ‘dns_manager.sh’ saved [6765/6765]
selecting download node...
Last metadata expiration check: 3:32:07 ago on Tue 26 Apr 2022 09:47:14 PM GMT.
No match for argument: pdns
Error: Unable to find a match: pdns
groupadd: group 'named' already exists
useradd: user 'named' already exists
mv: cannot stat '/etc/pdns/pdns.conf': No such file or directory
/etc/pdns/pdns.conf: No such file or directory
chmod: cannot access '/etc/pdns/pdns.conf': No such file or directory
chmod: cannot access '/var/named/chroot/var/named/*': No such file or directory
Failed to stop named-chroot.service: Unit named-chroot.service not loaded.
Failed to disable unit: Unit file named-chroot.service does not exist.
Failed to enable unit: Unit file pdns.service does not exist.
Failed to restart pdns.service: Unit pdns.service not found.
dns_manager.sh: line 114: /usr/bin/pip: No such file or directory
{"product": "Linux panel", "setup_path": "/www/server", "openlitespeed_path": "/usr/local", "language": "English", "title": "aaPanel Linux panel", "brand": "aaPanel", "root_path": "/www", "template": "default", "logs_path": "/www/wwwlogs", "home": "https://www.aapanel.com", "recycle_bin": true}
--2022-04-27 01:19:23-- https://node.aapanel.com/install/plugin/dns_manager_en/dns_manager_main.py
Resolving node.aapanel.com (node.aapanel.com)... 104.21.79.196, 172.67.171.7, 2606:4700:3031::6815:4fc4, ...
Length: 93588 (91K) [application/octet-stream]
Saving to: ‘/www/server/panel/plugin/dns_manager/dns_manager_main.py’
0K .......... .......... .......... .......... .......... 54% 562K 0s
50K .......... .......... .......... .......... . 100% 125M=0.09s
2022-04-27 01:19:25 (1024 KB/s) - ‘/www/server/panel/plugin/dns_manager/dns_manager_main.py’ saved [93588/93588]
--2022-04-27 01:19:25-- https://node.aapanel.com/install/plugin/dns_manager_en/index.html
Length: unspecified [text/html]
Saving to: ‘/www/server/panel/plugin/dns_manager/index.html’
0K .......... .......... .......... .......... .......... 90.2M
50K .......... .......... .......... ....... 32.6M=0.002s
2022-04-27 01:19:26 (51.2 MB/s) - ‘/www/server/panel/plugin/dns_manager/index.html’ saved [89934]
--2022-04-27 01:19:26-- https://node.aapanel.com/install/plugin/dns_manager_en/info.json
Length: 267 [application/json]
Saving to: ‘/www/server/panel/plugin/dns_manager/info.json’
0K 100% 13.0M=0s
2022-04-27 01:19:27 (13.0 MB/s) - ‘/www/server/panel/plugin/dns_manager/info.json’ saved [267/267]
--2022-04-27 01:19:27-- https://node.aapanel.com/install/plugin/dns_manager_en/icon.png
Length: 1505 (1.5K) [image/png]
Saving to: ‘/www/server/panel/plugin/dns_manager/icon.png’
0K . 100% 49.5M=0s
2022-04-27 01:19:27 (49.5 MB/s) - ‘/www/server/panel/plugin/dns_manager/icon.png’ saved [1505/1505]
|-Successify ---Script execution completed---
