armghan3071
Hello, after the server restarts, the aapanel does not start, the website does not start, please check whether the system and disk are abnormal?
Normal re-server will not have the problem of data loss,
Whether aapanel is started, you can use this command to check: bt status
Start it if it doesn't: bt start
Set boot up: update-rc.d bt defaults
If the website is nginx, please use:
/etc/init.d/nginx start
If the website is apache, please use:
/etc/init.d/httpd start
View the system log:
tail -n100 /var/log/syslog
