REQUEST_DATE: 2022-04-14 07:56:23
PAN_VERSION: 6.8.16
OS_VERSION: CentOS 7.8.2003 x86_64(Py3.7.8)
REMOTE_ADDR: 114.125.56.168
REQUEST_URI: POST /plugin?action=get_index_list
REQUEST_FORM: {}
USER_AGENT: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/100.0.4896.75 Safari/537.36
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 160, in new_conn
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/connection.py", line 61, in create_connection
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/socketcommon.py", line 230, in getaddrinfo
File "src/gevent/event.py", line 305, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 335, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 323, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 303, in gevent.gevent_cevent.AsyncResult.raise_exception
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/threadpool.py", line 142, in __run_task
socket.gaierror: [Errno -2] Name or service not known
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 381, in make_request
self.validate_conn(conn)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 978, in validate_conn
conn.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 309, in connect
conn = self.new_conn()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 172, in _new_conn
urllib3.exceptions.NewConnectionError: : Failed to establish a new connection: [Errno -2] Name or service not known
timeout=timeout
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 727, in urlopen
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 439, in increment
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+BT+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -2] Name or service not known'))
File "/www/server/panel/BTPanel/init.py", line 1578, in publicObject
File "/www/server/panel/BTPanel/init.py", line 1526, in run
File "class/panelPlugin.py", line 708, in get_index_list
softList = self.get_cloud_list(get)['list']
File "class/panelPlugin.py", line 353, in get_cloud_list
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 119, in post
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 530, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 643, in send
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+BT+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -2] Name or service not known'))
I have clicked the Fix button in the Home, but still error
