aaP_ibba_reda hey i have problem with my aapanel cpu 100% and load 100% check this i see a website i have a lot of new users can you pliz do something?
aaPanel_Kern Hello, what is your website program? It seems there is a security issue. Check whether the website program is the latest version? aaP_ibba_reda
aaP_ibba_reda aaPanel_Kern yes i have the latest update wordpress and programms is just simple website about manga can you pliz do something
aaPanel_Kern It is recommended that you first check which process has the highest usage among the processes. aaP_ibba_reda
aaPanel_Kern Hello, the process displayed is not normal. You need to check by yourself what this process does? aaP_ibba_reda
Brain I just finished installing Aapanel, after I opened Aapanel why is the Load Status 100% please help me...
aaPanel_Kern Hello, is the problem solved? Are you installing the program? Please place your cursor in the corresponding chart to view specific program usage Brain
Brain i alredy update Nginx, and add site... some times Load Status is 63%, 86%, 91%, and 100% whats wrong from my aaPanel, i mean... it's just finished installing and i don't install any program anymore
