Facing same issue there is any solution . i also try to reinstall PM2 manager unable to do it here is log when reinstalling
--2024-04-23 19:31:36-- https://node.aapanel.com/install/3/pm2.sh
Resolving node.aapanel.com (node.aapanel.com)... 104.21.79.196, 172.67.171.7, 2606:4700:3031::6815:4fc4, ...
Length: 14254 (14K) [application/octet-stream]
Saving to: ‘pm2.sh’
0K .......... ... 100% 64.4M=0s
2024-04-23 19:31:36 (64.4 MB/s) - ‘pm2.sh’ saved [14254/14254]
selecting download node...
https://na1-node.bt.cn
{"product": "Linux panel", "setup_path": "/www/server", "openlitespeed_path": "/usr/local", "language": "English", "title": "aaPanel Linux panel", "brand": "aaPanel", "root_path": "/www", "template": "default", "logs_path": "/www/wwwlogs", "home": "https://www.aapanel.com", "recycle_bin": true}
--2024-04-23 19:31:51-- https://dg2.bt.cn/install/plugin/pm2_en/pm2_main.py
Resolving dg2.bt.cn (dg2.bt.cn)... 128.1.164.196, 2001:19f0:7001:54fc:5400:2ff:fe9b:97f9
Connecting to dg2.bt.cn (dg2.bt.cn)|128.1.164.196|:443... connected.
Length: 24357 (24K) [application/octet-stream]
Saving to: ‘/www/server/panel/plugin/pm2/pm2_main.py’
0K .......... .......... ... 100% 29.7M=0.001s
2024-04-23 19:31:52 (29.7 MB/s) - ‘/www/server/panel/plugin/pm2/pm2_main.py’ saved [24357/24357]
--2024-04-23 19:31:52-- https://dg2.bt.cn/install/plugin/pm2_en/index.html
Length: 53079 (52K) [text/html]
Saving to: ‘/www/server/panel/plugin/pm2/index.html’
0K .......... .......... .......... .......... .......... 96% 402K 0s
50K . 100% 3500G=0.1s
2024-04-23 19:31:52 (417 KB/s) - ‘/www/server/panel/plugin/pm2/index.html’ saved [53079/53079]
--2024-04-23 19:31:52-- https://dg2.bt.cn/install/plugin/pm2_en/info.json
Length: 324 [application/json]
Saving to: ‘/www/server/panel/plugin/pm2/info.json’
0K 100% 32.5M=0s
2024-04-23 19:31:52 (32.5 MB/s) - ‘/www/server/panel/plugin/pm2/info.json’ saved [324/324]
--2024-04-23 19:31:52-- https://dg2.bt.cn/install/plugin/pm2_en/icon.png
Length: 1017 [image/png]
Saving to: ‘/www/server/panel/plugin/pm2/icon.png’
0K 100% 72.4M=0s
2024-04-23 19:31:53 (72.4 MB/s) - ‘/www/server/panel/plugin/pm2/icon.png’ saved [1017/1017]
/www/server/panel/static/img/soft_ico/ico-pm2.png: No such file or directory
