aaPanel_Kern varundeva Hi, I don't see any errors from the installation log: Can you provide the running log. or cat /www/server/mongodb/log/config.log
aaPanel_Kern varundeva Can you send me your aapanel login information, if possible, please send it to: kern@aapanel.com
aaPanel_Kern varundeva Hello, after querying the mongodb on aapanel, the arm platform has not been matched, so it cannot be started.
varundeva aaPanel_Kern Ok. So in AAPanel Email and MongoDb are not Supported. I think through docker MongoDB can be run right? Anyone have proper Docker configuration guide please provide.
varundeva aaPanel_Kern I'm asking docker guide for AAPanel In terminal just docker run image name or docker compose up command But in aa panel docker plugin is something different I couldn't find proper documentation or tutorials
aaPanel_Kern varundeva Hello, you need to install before using docker, you can install Docker Manager 3.4 in aapanel
varundeva aaPanel_Kern i have installed docker manager. I have docker compose file also for my project in github But here how to run
aaPanel_Kern varundeva Hello, if you are running mongo, you can pull the mirror here Create the container again:
