aaP_owais9229 I just installed aapanel and selected ssl from settings. Now I can't access my panel. Because it automatically redirects to https. I want to deactivate https redirect from cmd. Is it possible?
aaPanel_Kern aaP_owais9229 You can turn off SSL by manually entering the following command on SSH. rm -f /www/server/panel/data/ssl.pl && /etc/init.d/bt restart
aaP_jeftermendonca How I turn on SSL? The certbot is redirecting the certificate of atende.supremanet.com to typebot.supremanet.com. Can you help me?
