Hi!
For some time now, I have had a problem on "Mail Server" with refresh records.
I am fresh after the clean installation (2 days ago), I was doing the installation because there was this problem. Now it's the same again. I had 2 days of peace. Please support for help in solving. Maybe some update?
`Sorry, something went wrong๏ผ
raise NotFound()
File "class/panelPlugin.py", line 2103, in a
return eval(execStr)
File "", line 1, in
File "/www/server/panel/plugin/mail_sys/mail_sys_main.py", line 349, in flush_domain_record
public.writeFile(self.session_conf, json.dumps(self.session))
File "/www/server/panel/pyenv/lib/python3.7/json/init.py", line 231, in dumps
return _default_encoder.encode(obj)
File "/www/server/panel/pyenv/lib/python3.7/json/encoder.py", line 199, in encode
chunks = self.iterencode(o, _one_shot=True)
File "/www/server/panel/pyenv/lib/python3.7/json/encoder.py", line 257, in iterencode
return _iterencode(o, 0)
File "/www/server/panel/pyenv/lib/python3.7/json/encoder.py", line 179, in default
raise TypeError(f'Object of type {o.class.name} '
TypeError: Object of type A is not JSON serializable`
