Vereato error on installing this apps apache purefptd php 7.4 php 7.2 this apps can be installed on ubuntu 20.04.2
Vereato as you can see it loads and never stops and not install the scripts as i can show you the scripts are installed the php 7.4 not installed and pure sftp not installed the log shows gcc packages
Vereato i tried to install i believe it needs some packages do you have the packages i can download for my ubuntu groovy i m using the ubuntu versions 20.10 i cant find the packages i tried to download from ubuntu servers and says not found
