Anyone cam help me, plz?
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+BT+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -2] Name or service not known'))
REQUEST_DATE: 2022-02-11 17:15:30
PAN_VERSION: 6.8.21
OS_VERSION: CentOS Stream 8 x86_64(Py3.7.8)
REMOTE_ADDR: 177.128.124.77
REQUEST_URI: POST /plugin?action=get_usually_plugin
REQUEST_FORM: {}
USER_AGENT: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/98.0.4758.82 Safari/537.36
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 175, in new_conn
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/connection.py", line 72, in create_connection
File "src/gevent/event.py", line 329, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 359, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 347, in gevent.gevent_cevent.AsyncResult.get
File "src/gevent/event.py", line 327, in gevent.gevent_cevent.AsyncResult.raise_exception
socket.gaierror: [Errno -2] Name or service not known
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 710, in urlopen
chunked=chunked,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 386, in make_request
self.validate_conn(conn)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 1040, in validate_conn
conn.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 358, in connect
conn = self.new_conn()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 187, in _new_conn
urllib3.exceptions.NewConnectionError: : Failed to establish a new connection: [Errno -2] Name or service not known
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 450, in send
timeout=timeout
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 786, in urlopen
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 592, in increment
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+BT+account+first&environment_info=%7B%7D (Caused by NewConnectionError(': Failed to establish a new connection: [Errno -2] Name or service not known'))
File "/www/server/panel/BTPanel/init.py", line 1578, in publicObject
File "/www/server/panel/BTPanel/init.py", line 1526, in run
File "class/panelPlugin.py", line 1880, in get_usually_plugin
plugin_info = self.get_soft_find(p['plugin_name'])
File "class/panelPlugin.py", line 947, in get_soft_find
softList = self.get_cloud_list(get)['list']
File "class/panelPlugin.py", line 361, in get_cloud_list
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 117, in post
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 529, in request
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/sessions.py", line 645, in send
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 519, in send
