requests.exceptions.SSLError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+BT+account+first&environment_info=%7B%7D (Caused by SSLError(SSLEOFError(8, 'EOF occurred in violation of protocol (_ssl.c:1091)')))
REQUEST_DATE: 2022-02-10 09:20:46
PAN_VERSION: 6.8.21
OS_VERSION: CentOS 7.9.2009 x86_64(Py3.7.9)
REMOTE_ADDR: 10.192.153.42
REQUEST_URI: POST /plugin?action=get_soft_list
REQUEST_FORM: {'p': '1', 'type': '0', 'tojs': 'soft.get_list', 'force': '0', 'query': ''}
USER_AGENT: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/98.0.4758.82 Safari/537.36
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 696, in urlopen
self._prepare_proxy(conn)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connectionpool.py", line 964, in prepare_proxy
conn.connect()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 359, in connect
conn = self.connect_tls_proxy(hostname, conn)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/connection.py", line 502, in connect_tls_proxy
ssl_context=ssl_context,
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/ssl.py", line 432, in ssl_wrap_socket
ssl_sock = ssl_wrap_socket_impl(sock, context, tls_in_tls)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/ssl.py", line 474, in ssl_wrap_socket_impl
return ssl_context.wrap_socket(sock)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/ssl3.py", line 120, in wrap_socket
session=session)
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/ssl3.py", line 312, in init
raise x
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/ssl3.py", line 308, in init
self.do_handshake()
File "/www/server/panel/pyenv/lib/python3.7/site-packages/gevent/ssl3.py", line 667, in do_handshake
self.sslobj.do_handshake()
ssl.SSLEOFError: EOF occurred in violation of protocol (ssl.c:1091)
timeout=timeout
File "/www/server/panel/pyenv/lib/python3.7/site-packages/urllib3/util/retry.py", line 573, in increment
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='brandnew.aapanel.com', port=443): Max retries exceeded with url: /api/panel/getSoftList?status=False&msg=Please+login+with+BT+account+first&environment_info=%7B%7D (Caused by SSLError(SSLEOFError(8, 'EOF occurred in violation of protocol (_ssl.c:1091)')))
File "/www/server/panel/BTPanel/init.py", line 1578, in publicObject
File "/www/server/panel/BTPanel/init.py", line 1526, in run
File "class/panelPlugin.py", line 685, in get_soft_list
softList = self.get_cloud_list(get)
File "class/panelPlugin.py", line 361, in get_cloud_list
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/api.py", line 119, in post
File "/www/server/panel/pyenv/lib/python3.7/site-packages/requests/adapters.py", line 514, in send
raise SSLError(e, request=request)
