ERR_ADDRESS_UNREACHABLE after update to 6.1.1
please run this command and show me the result.
tail -n 100 /www/server/panel/logs/error.log
Hello Jose.
We add website to aaPanel, it's Wordpress CMS (migration from A to B hosting). And after that import SQL and files, change IP configuration file too of course. And we add new IP to hosts, try to look website but get this error:
We get ping from URL name (it's interesting), but when try open website (after adding IP for domain in /hosts file) website doesn't opening.
Orkhan
What is prompted when you ping the domain name?
Hello. Domain is on new server with aaPanel.
Orkhan Sir, I'm sorry. You may need to check the communication status of the domain name. According to the error message, this may be caused by the domain name being unable to communicate.
Hey @aapanel_sniper.
Thank you for your reply. We change config file but it's still have problem :/
Orkhan This is estimated to have nothing to do with the site configuration. You need to check the firewall in the system and the firewall of the vps server provider to see if port 80 is allowed.
At the same time, you can send the domain name to my mailbox, and I will test the connection.
I'm having this error. I installed aapanel yesterday and today I can't access it anymore.
Hello, is the problem solved? Is it normal to try using this command to repair the update?
rm -f /tmp/update_to7.pl && curl -k https://node.aapanel.com/install/update_7.x_en.sh | bash
