JAY aaPanel_Jose in centos 8 iam unable to enable ssl on mysql - after i enable it come backes to disable mode in centos 7 i can enable but password error still same error ERROR 1045 (28000): Access denied for user 'database'@'localhost' (using password: YES)
duchiep aaPanel_Jose OpenLiteSpeed Web Server (beat) is expected to be released next week great news ^^....thank for your work hard
html in the demo panel i cannot see the right most side of the appstore. Kindly update the version also of demo. https://i.imgur.com/lf8aQuy.jpg Also add scrollbars inside popups. cannot see bottom buttons properly... https://i.imgur.com/fqkeGGh.jpg
spectra I am having issue in my aaPanel after updating the panel can not load in browser and also in the terminal bt command dose not run. Could you please guide me how can i get back my panel or repair my panel? Thanks
aaPanel_Jose spectra You can use the installation panel command to overwrite the installation, this will not damage your existing data
