Hi guys.
Can't I get a certificate when using nginx reverse proxy? On the nginx module when I try to get one it says "Sites with reverse proxy turned on cannot apply for SSL!"
How should I proceed?
Got it.
But I would suggest a change for that message...
I had to remove reverse proxy before adding the SSL certificate and finally config the proxy again. So it seems that message could be "disable/remove reverse proxy before the ssl" or even better, support it no matter the order.
Regards.
    4 years later
    Hi, guys,
    how to make the connection from ngix reverse to backend use SSL?
    because my backend server detects reverse proxy using port http or 80
