wrong reason:
In order to improve security, aaPanel has enabled secure directory login by default. Each installed panel will randomly have an 8-character directory name. You can modify it in the panel settings. If you do not record or remember, you can use the following methods solve
Solution:
Log in to the SSH terminal and enter one of the following commands to solve
- View the panel security entry:
/etc/init.d/bt default
- Turn off entrance verification (It is not recommended to close, it will make your panel less secure):
rm -f /www/server/panel/data/admin_path.pl
