Post link:
Detailed problem description:
aaP_mihonukr
    aaP_mihonukr
    Please download and compress these files into one file and send it to us via email. Thank you.
    /www/server/panel/data/default.db
    /www/server/panel/data/db/ssl_data.db
    /www/server/panel/config/letsencrypt.json
    /www/server/panel/config/letsencrypt_v2.json
    5 months later
    Hello, can you solve this problem by clicking "Fix" on the Home to fix it?
    duzorg
      No. In log now
      /www/server/panel/mod/base/web_conf/access_restriction.py:136: SyntaxWarning: invalid escape sequence '\.'
      suffix_template = '{tmp_pre}if ( $uri ~ "\.({suffix})$" ) {{\n{tmp_pre} return 404;\n{tmp_pre}}}'
      /www/server/panel/mod/base/web_conf/access_restriction.py:137: SyntaxWarning: invalid escape sequence '\.'
      suffix_template2 = 'if ( $uri ~ "^{path}.*\.({suffix})$" ) {{\n return 404;\n}}\n'
      /www/server/panel/mod/base/web_conf/proxy.py:120: SyntaxWarning: invalid escape sequence '\,'
      return "代理目录不能有以下特殊符号 ?,=,[,],),(,*,&,^,%,$,#,@,!,~,
      /www/server/panel/mod/base/web_conf/ssl.py:970: SyntaxWarning: invalid escape sequence '\s'
      rep_https = re.compile("\n\s*#HTTP_TO_HTTPS_START(.|\n){1,300}#HTTP_TO_HTTPS_END&quot😉
      |-Renewing the 1 certificate,There are 3 certificates in total...
      |-【f9fe806874a7b391ecfb4dde75e7046d】The specified certificate information was not found and the renewal cannot be carried out!
      |-Renewing the 2 certificate,There are 3 certificates in total...
      |-【af507e1c21c21f008a7aee790ee7baa8】The specified certificate information was not found and the renewal cannot be carried out!
      |-Renewing the 3 certificate,There are 3 certificates in total...
      |-【3df6b0a262fe2e4d4d5c55b095a5b089】The specified certificate information was not found and the renewal cannot be carried out!
      ★[2025-02-18 13:32:48] Successful
      ★[2025-02-18 13:34:51] Successful
        Post link:
        duzorg
          8 days later
          How to solve it, please? Extending SSL work only by manually clicking (which is annoying), but cron job does not. I did a "fix" on aapanel and it does not help.
          PS. /www/server/panel/pyenv/bin/python /www/server/panel/class/acme_v2.py --renew_v2=1 gives the same result.
            9 days later
            Currently, only SSL will be automatically renewed within 30 days.
            If there is any problem with the data recorded before, it will not be re-renewed correctly. You need to update the panel to the latest version, then Disable SSL, and then re-apply for SSL to allow other records to be correct.
            aaP_alamat.emailnya.riyan
