JAY ducdo login to ssh and try bt command and then you will see repair panel once repair is done reboot server
ducdo JAY i try repair, but i still can't access to aapanel web This link: https://157.245.145.238:8888/401bbf0a
aaPanel_Jose ducdo If you can't fix it by yourself, you can send the server ssh login information to my mailbox, I will fix it for you as soon as possible
JAY aaPanel_Jose dont forget to add cache deletion and adding headers either its caching not to check hit or miss option which is missed that image
aaPanel_Jose jazz1611 Thank you for your suggestion, we will first record to consider the development
