theglassicon Hello all, I updated panel to 6.6.2 and now i get a connection refused when i try to login to panel. Panel restarts fine through bt commend. Is there anything i can check, change to fix this? Thank you
theglassicon Thank you for your answer, already tried that and when it finishes says cannot start panel.
theglassicon By mistake Python 3.6 was installed in the system, changed to 2.7 and now it runs. Thank you.
MegaApps hello, I can't enter the panel. I get an unsecured connection. I do not know what to do now.
