JAY
Regarding the first question, the update of the panel will not affect the use of other services, because the panel is only an independent management process. If you cannot find the reason, you can send me the login information of the panel, and I can help you check it.
Regarding the second question, you can drag the icon and swap the other icons, and then it will be normal. This is a bug that has been left unfixed before
The last issue we will fix as soon as possible
