whitei First off thanks for creating such a super panel. Just found a couple of minor issues, maybe you can patch in a future version. Rename 'Totally Sent' to 'Total Sent', same for received. Text found on homepage under traffic section. (Grammar Issue). Remove hard-coded width of '700px' from backup/restore popup. Once removed the panel will scale correctly and not hide restore button. https://i.imgur.com/G7le0cq.jpg https://i.imgur.com/BlqFbAO.png Thanks in advance.
